I believe my antenna (by checking from the ground) is not quite pointed at 150 degrees. I'm using my rotor to dial in the strongest signal I can get for FOX 69.1 which is at 150 degrees. When I get a peak signal for FOX (69.1), then CBS (8.1) becomes choppy even though it's reporting strong peak signals.
Thanks,
Joseph Elwell.
