Old 19-Jun-2015, 9:53 PM   #23
jelwell
I currently have a Winegaurd HD7697P (that I borrowed from my friend). It is attached to a chimney mount.
The mast is grounded to the same grounding pipe/conduit that my solar panels ground on.
The mast is hooked up to a rotor, so that I can rotate it from the comfort of my TV room. No more climbing up and down checking signal strengths. Or begging someone to sit through and document everything for me.
The cable line runs down to my house, into the pre-amp (RCA TVPRAMP1R) and then into a surge protector and then into my TiVo. I've taken the surge protector out of the equation before and it doesn't seem to make much difference.
The cable is R6 outdoor rated.
My chimney mount still has my old Clearstream 4 (above) the Winegaurd. Unfortunately the Clearsteam 4 was unreliable. I was unable to receive Fox (69.1) reliably, as well as other stations. In particular, from what I read about my TiVo's tuner it does not handle multicast well, so a directed antenna like the Wineguard is suggested. If you scroll back in this thread far enough you'll see that my Samsung TV's tuner gets all the stations and more with the clearstream - like 50 or more stations reliably. Unfortunately the TiVo is a dealbreaker - it needs to be in the loop.
Picture: http://postimg.org/image/5f0iuugyn/
I just tried removing the pre-amp here are the readings (I always list peak readings, not average):
ABC 10-1 70
CBS 8-1 71
NBC 39-1 31
FOX 69-1 40
PBS 15-1 42
CW 6-1 22 (not enough to display)
iON 30-1 301 (choppy)
KUSI 51-1 23 (not enough to display)
Most notably ABC (10-1) does not seem to stutter, and the readings aren't fluctuating wildly. So likely the pre-amp was not helpful.
NBC (39-1) is very close to the minimum required for a signal lock which is scary.
Here's with the pre-amp re-connected (so that weather/etc isn't distracting the numbers):
ABC 10-1 70 (choppy)
CBS 8-1 74
NBC 39-1 31 (choppy)
FOX 69-1 40
PBS 15-1 41
iON 30-1 83 (moving wildly, not displaying)
KUSI 51-1 26 (broken up)
It seems like the pre-amp isn't helping. Without the pre-amp the channels I want, ABC, CBS, NBC, FOX & PBS all come in (today) - but some are on the cusp of not coming in which worries me as it is a very clear day today. The CW (6-1) would be nice to get but not a deal breaker. iON and KUSI, I wouldn't bother to put any effort into receiving.
Indeed I am in a depressed area. I live on Black Mountain. Near here:
https://www.google.com/maps/place/32°58'36.4"N+117°07'45.8"W
There is a ridge that is higher than my chimney to the south of me.
Joseph Elwell.
jelwell is offline   Reply With Quote
