thank you so much for your info and help. Am I to assume that the FM signals you mentioned would interfere with my TV signal, and that there is some type of device that would be installed to filter them out? Also, these two antenna models that you suggested, should they be mounted in a certain direction facing either north or south, or are they multi-directional?
