Old 15-Jun-2015, 7:01 PM   #4
Welcome back. You have three other threads with the same problem, so we have to read them first before answering. It would have been easier if you had continued on the original thread. Your previous threads:
Throwing TV Signal Downstairs
http://forum.tvfool.com/showthread.php?t=13985
Originally Posted by voidcomp View Post
More of an observation - signal to a downstairs TV can be problematic without direct cabling, split or otherwise, from the roof/attic mounted antenna. Lots of discussions here about throw length, amplification, etc.
An alternative - attach the antenna cable to a HDHomerun, which in turn is connected via cat5 to a wireless switch. So long as you have a laptop/computer downstairs connected to the basement TV (HDMI preferably) and the distance or interference isn't too great, simply install the HdHomerun Quick TV software to the computer.
Pretty quick and dirty. I'm actually getting decent OTA pictures, even when thrown over Wireless G.
Are you having the problem now with the TV or the wireless with HDHR?
Intermittent Interference
http://forum.tvfool.com/showthread.php?t=13890
Not sure if this makes any difference but there's a police and fire transmitter directly, and I mean directly in line, roughly 1/2 mile away. Could this possibly be the source of interference?
If you were able to determine what frequency(ies) the public service agencies are operating on, then you could install a frequency selective filter to attenuate them from the input of your set(s).
For testing, you could use the UHF input of a UVSJ to trap out the VHF band since that appears to be where most of your local police dispatch appears to operate. That would at least give you an idea if interference from the VHF band is the issue.
Unfortunately, many of the other public services use UHF frequencies almost adjacent to UHF channel 14 (450-470 MHz), so filtering them out would be a lot more difficult and you won't be able to pick something up at Radio Shack that will do the trick.
Did you try the UVSJ test, using the common and high ports, suggested by ADTech to see if it would remove the interference?
confused with results
http://forum.tvfool.com/showthread.php?t=13756
Good signal on all channels except WLLA Ch 45 which drops out now and then. No consistency to the pattern. Funny thing is, my indoor Mohu Leaf on another tv pulls in the station better (at the expense of other stations not coming in).
I can see it's in a fringe zone, yet stations WOLP and WZPX (with lower NM's) come in just fine. WZPX is in a significantly different direction too which is kind of surprising considering the direction sensitive nature of the antenna.
Can anyone shed some light as to why some stations one would think would come in poorly come in fine, and vice versa?
There's no erratic behavior with the Mohu Leaf. Reason?
Interesting, the Leaf is lower, within the house, subject to more interference and blockage, and considerably less powerful than the Winegard.
The acid test will come when I install a HDHomerun and see if signal strength remains strong enough to record. Unfortunately my Vizio has no signal strength function to give me a ballpark idea.
The 7694 has more gain on VHF than the Leaf, so it is more likely to pick up VHF interference.
As previously mentioned, indoor and attic reception is difficult to predict. Antenna location can be critical and signal loss from the attic location is unknown.
It is possible that the HDHR is more easily overloaded than the TV by strong signals.
You have some strong FM signals. In addition to the UVSJ test, you should try an FM filter. See attachment.
http://comingsoon.radioshack.com/rad...l#.VX8mYzjbKHw
A 4G filter would be worth a test; the interference might be coming from above channel 51.
https://en.wikipedia.org/wiki/4G-LTE_filter
https://at800.tv/find-out-more/
http://www.digitalhome.ca/forum/81-o...ml#post1911626
http://www.avsforum.com/forum/25-hdt...l#post24603050
If you could tell us more about the police and fire station, maybe we could find out the transmitter frequencies.
