Old 13-Jun-2015, 11:27 PM   #18
nomanselizabeth
Talking
Sorry for the delay in responding - work this week turned into a bigger hurry than usual!
I have added two FM traps in serial inside the house, just before the TV Antenna IN, seperated by a 1ft length of RG6. This has had the effect of returning the reception to the state it was when the antenna was installed i.e. I have Channel 46 back in lovely high def, Channel 11 is back, pixelated when first tuned in but clearing after a couple of minutes, and Channel 8 is viewable although tending to pixelate every so often.
In other words, the FM traps seem to have worked at restoring the set up to original condition, with a minimum of fuss and expense. Thank you so much for your advice, gentlemen! I really appreciate it!
nomanselizabeth is offline   Reply With Quote
