I have tried moving the antenna onto a wooden bookcase with no difference in signal with the metal ladder well away from the antenna. I did move the antenna outside but lost all signal maybe because of the length or the cable, it was an RG6 U Quad shielded cable but 50ft. I plan on keeping the antenna in the attic, so going outside with was not as important. I was surprised I lost all signal. I did buy a dist amp from Lowes and it did increase the signal strength a little bit but it was a 4 outlet dist amp so I returned it.
