Please get the antenna
out of the garage and at least 5' away from that
metal stepladder.
10ft cable from antenna to filter and then into my house cable.
Please use a known good cable to run from the antenna (filter) to your TV set. You need to eliminate as many variables as possible as well as correcting issues that are likely to cause your symptoms.
