Old 13-Jun-2015, 2:14 AM   #2
Sorry, there is no magic antenna that will see through trees.
If a tree loses its leaves in the fall, reception behind it will improve dramatically. Many people get a TV for Christmas, and erect an antenna for it in January, and then wonder why it quit working in May. It’s the trees.
http://www.hdtvprimer.com/ANTENNAS/siting.html
scroll down to Trees and UHF
Can you aim between them or below them from any location on your property?
WTVF is not a UHF channel, it is a VHF-Low channel on real channel 5, which requires a BIG antenna. It is the real channel number, not the virtual channel number, that determines the proper antenna.
VHF-Low, real channels 2-6
VHF-High, real channels, 7-13
UHF, real channels 14-51
If you take the splitter out, it will make your signals a little stronger, but it might not make any difference.
