Old 12-Jun-2015, 9:50 PM   #2
Interesting antenna. Looks like it is for VHF real channels 2-13. Most of your channels are UHF with the exception of WKRC on CH 12. You would need something like an RCA ANT751 or a Winegard HD7694P, no amp.
You have some very strong FM signals that might cause interference. I don't have your exact address, so I used your short coordinates to make an FMFOOL report. Insert an FM trap, or 2 in series.
http://comingsoon.radioshack.com/rad...l#.VXto6DjbJLM
I know I need a balun, but where do I connect it to on the antenna.
You would probably connect the balun to the center of one of the long elements (maybe the middle one), where there should be 2 wing nuts. I would need a closeup to tell for certain.
http://www.channelmaster.com/TV_Ante...p/cm-94444.htm
http://www.homedepot.com/p/Channel-M...4444/203763061
http://www.mcmelectronics.com/produc...94444-/30-2570
Even if your antenna doesn't look like it's the right one for your signals, you should try it first if you can get to it easily.
