Lara. If zoning will allow it, you could also have someone install a utility pole on the property for you to install a mast and antenna on top. If your yard is large enough that may be doable and will likely cost less than a tall free standing tower. Just make sure you get the pole with spikes on it to climb. Otherwise you will need to rent a cherry picker.
