Old 11-Jun-2015, 9:13 PM   #3
frank55
frank55's Avatar
You have some very strong signals that might overload the preamp.
What signals are you getting, by real channel?
What signals do you want that you are not getting?
Why aren't you happy with your present setup?
If you use a preamp and your present istribution amp, your tuner will probably be overloaded.
For best reception of digital signals, your antenna should be aimed the transmitter. What direction are you going to settle on?
Thanks what i want to do is to take out this one that is close to the receiver that is amplifying antenna signal' i have fear signal from about 50 miles out of Boston
http://forums.qrz.com/showthread.php...two-RG6-cables
and replace with this one close to antenna.
http://www.amazon.com/Winegard-LNA-2...enna+amplifier
frank55 is offline   Reply With Quote
