Old 11-Jun-2015, 8:04 PM   #2
You have some very strong signals that might overload the preamp.
What signals are you getting, by real channel?
What signals do you want that you are not getting?
Why aren't you happy with your present setup?
If you use a preamp and your present distribution amp, your tuner will probably be overloaded.
i cut off boom in half and some VHF elements left only 3 VHF on the back,the antenna is the one that is in my avatar,just don't use the rota-tor no more cause it failed.
For best reception of digital signals, your antenna should be aimed the transmitter. What direction are you going to settle on?
