Old 11-Jun-2015, 12:14 AM   #1
DougM
Suggestions please to improve attic installation.
Hello,
Here's a link to my TV fool report
http://www.tvfool.com/?option=com_wr...8230c75660bf63
I'm trying to get an in-attic installation working, and so far it's not great. I did have some success with a smaller antenna on a mast, so I was hoping that a larger one would be sufficient in the attic. We have shingles on plywood construction, single storey.
I'm using a Winegard 7697, and a LN-100 pre-amp located with the antenna in the attic. The antenna is aimed pretty much at 170 magnetic, +- < 10 degrees. The coax run after the amp is about 35 feet to a Hauppage tuner card. I'm getting only a couple of decent channels. removing or adding the amp doesn't change much.
Could I have a bad tuner card?
regards
Doug
DougM is offline   Reply With Quote
