Hmmm...
What are the odds that you can utilize that power line pole at the end of the driveway (where the transformer is mounted) without causing a safety issue (or raising Ameren's ire) and then run a coax back to the house? Just brainstorming, trying to get out from behind that large tree near the road. Of course, others will note that putting an antenna that close to a transformer has the potential of opening its own can of worms.. but we're just thinking outside that old box for a bit.
If that spot shouldn't be available, how about an alternate ground-mounted location that clears that tree?
I'll send you (momentarily) a link to a photo on my Google Drive that will help show the signal paths from your rooftop. I purposely set the antenna height to 150' to make the signal path lines more visible.
