Old 10-Jun-2015, 11:37 AM   #2
No static at all
No static at all's Avatar
You have a few suspect FM stations that may be causing issues with channel 7. Not sure if the FM trap is sufficient on that amplifier? Did you ever test reception with no amplifier & the antenna connected directly to 1 TV? (no splits)
Do you get the same results on more than one TV?
