Old 10-Jun-2015, 2:33 AM   #1
jvaldovi93550
Channel 7 KABC Reception in Palmdale, CA
Hello,
I have a Winegard HD8200U TV Antenna mounted on a mast outside my house in Palmdale, CA. It is about 20 feet above the ground. I get most of the local channels clearly. However, according to my TV Fool report, I should be able to get Channel 7 KABC. I already tried adjusting the height and angle. Raising the antenna actually made the signal worse, which confuses me. My TV Fool Report is shown below. I have a Winegard LNA200 amplifier mounted on the mast. I spoke with a technical person at Channel 7. They say that their signal is not as strong as the TV Fool Report shows. Any suggestions on how to pick up Channel 7? Thank you.
http://www.tvfool.com/?option=com_wr...82306c55c20beb
jvaldovi93550 is offline   Reply With Quote
