First things first. Install an FM Filter.
WLOS' signal is forecast to be "very strong". Most likely, you're getting interference, either from FM or some other, less obvious noise source, and it's clobbering WLOS' signal. If you amplify a noisy signal, you get a bigger pile of noisy stuff.
