Old 9-Jun-2015, 4:10 PM   #3
Tim
Originally Posted by tlariviere View Post
It looks like CBS is pointed toward the North
Is W10AD on real channel 10 a translator for CBS??? If so, it is a VHF-Hi signal at 187 degrees (almost due South) which would also require a different antenna but has a decent signal at your location and is Line of Sight.
If you are speaking of CBS on channel 7 that is at 181 degrees, that is due South and as rabbit73 mentioned it is a VHF-Hi signal that would require a different antenna and is weaker at your location than W10AD, plus it is 2 Edge signal.
