Took a quick look at the report. Probably the Winegard 8200. May or may not need a rotor. Depends upon if you have multipath issues. I know I have several signals coming from 15 degrees at my home but they are pretty weak and I need to move the antenna a few inches to get one or two that won't come in a few inches in the other direction.
The Winegard 7698 would also work. But since you do have a Ch. 3 there and may want to watch it in the future if there is a programming change, might make sense to get the 8200.
