Old 8-Jun-2015, 9:27 PM   #12
nomanselizabeth
Gentlemen, I went by Frys' to get the FM traps but, by virtue of the fact that there were none on the racks, ended up talking to a salesman. He said that both local stations 11 & 46 changed towers a couple of months ago; he works part time at one of the other broadcast stations in-town and says this was mentioned in meetings at the time. He remarked that a number of people have been in with the same question and since the tower change is the issue (in his opinion), neither an FM trap nor a channel blocker will help. His solution is to re-aim the antenna.
I am skeptical of the 'tower change' as the Signal Analysis database that this site draws from shows it to have been updated only a few days ago. I do not see any change or even a variance in the direction of WXIA/WGCL from most of the other local channels.
But before I go buying things I don't need, or messing with cabling, I thought I would ask you if this makes any kind of sense to you.
nomanselizabeth is offline   Reply With Quote
