Old 8-Jun-2015, 2:02 AM   #13
Billiam
Originally Posted by navagator View Post
No, the signal level for WOI is very low, not enough for the tuner to lock onto.
However, I did receive WOI with the first converter box I had, at least part of the time anyway. I believe it was a Zenith DTT-901. As I remember that converter box worked pretty well but unfortunately it was SD only.
Tuner quality varies greatly in some TV's and also the converter boxes. Some TV's I've had such as a Sanyo stunk while others like a Sony and Samsung were excellent at least where picking up weak signals is concerned.
If after raising the antenna you see any other channels such as WOI but don't get a clean lock on it all the time, you may be able to fix the problem with the pre amp I recommended. Kitztech makes pre amps for very weak signal areas.
