Do you want to receive Ch. 5? Since all of the viewable signals are at the same compass reading it makes it easy to buy a single antenna and point it in that direction. Only buy a rotor if you plan to DX signals. Otherwise a fixed antenna will work.
You will probably want a pre amp as well. After choosing the antenna picking the right pre amp should be simple.
