Old 4-Jun-2015, 6:20 PM   #8
I wanted to look at your FM signals to see if they might be causing interference to your TV reception. I made an estimate of your location for a tvfool report that seemed to match yours:
http://www.tvfool.com/?option=com_wr...f1f071e1da6fc9
and I used that location to generate an FM FOOL report. See the attachment.
Multi-path is, by far, the most common type encountered. Small, not very directional antennas like the one you have are most susceptible to this issue.
I agree with ADTech. A more directional antenna might help.
I have it pointed at some transmitters located LOS 4.7 miles away. I know it's pointed in the right direction because I can actually see the transmitting towers from my roof
Channel 17 is not on that tower, it's on a tower at 5.0 miles away at a different azimuth. With an antenna that isn't very directional, it probably wouldn't make any difference, but what could it hurt to rotate it a little to the right? You could try a more directional antenna like the RCA ANT751.
There is a good chance that you are getting a reflected signal of CH 17 off the ridge at the rear of the antenna that is causing interference to the direct signal. An antenna with a good Front-to-Back ratio might help.
There is also the possibility of FM interference. Your strongest FM signal is KRJC with a strength of -16.8 dBm. It wouldn't cost much to insert an FM filter in the RG6 coax line as a test, but it would knock out real CH 6.
Is your coax grounded?
