Old 4-Jun-2015, 6:02 PM   #12
One last question, how can you tell if the fm trap is working on the rca?
The simple test would be to try it in or out on a problem channel. The next level would be to add a HLSJ or 2 in series, between the antenna and the preamp input. I assume you are using the combined all channel input. The next test level up would require lab equipment, but I think your Sony SNR and error readings would tell you a lot with problem channels.
