Old 4-Jun-2015, 11:49 AM   #3
john262
Move the antenna up and down the mast and retest.
If necessary, relocate the antenna elsewhere.
Thanks. So you think that even with the strong signal according to my TV's signal strength meter that means that it's a problem with the antenna's location? It's a direct line of sight already with no obstructions such as trees and buildings in the way at all. And why would it be affecting only one channel? According to the FCC's database all of the UHF translators I am pointing at are the same power, 1 kw. So why would one 1 kw transmitter come in OK while the other doesn't when they are both in the exact same location? Just wondering. Thanks.
john262 is offline   Reply With Quote
