Old 1-Jun-2015, 10:48 PM   #11
tekeeladude
Interesting - I've actually never seen that work......
I really think the problems I was experiencing are due to the tuner sensitivity in my main Visio TV. The other Visio TV doesn't seem to have the same issue using the same connection. I initially set the attenuator using the Hauppauge tuner and signal meter, but found that I could dial up the attenuation when using it with the main TV. So for in this particular instance, the adjustable attenuator works great.
tekeeladude is offline   Reply With Quote
