Response.
Thank you for the information. I do use a winegard pre-amp and their L290. You mentioned my antenna is pointed in the wrong direction. What would you advise? I use a compass setup for true North.
The winegard CC-7870 can combine a pre-amp antenna with an antenna without one. Not sure if this is worth trying. My friend let me use his HD8800 initially to test my reception. I can borrow it again for a 2 antenna test.
Nick
