Old 1-Jun-2015, 2:14 AM   #7
No static at all
No static at all's Avatar
Originally Posted by skatingrocker17 View Post
Yes I can. I live about 8 miles from metro airport.
Then airplane flutter is the likely culprit IMO. If true your good & bad days will be dictated by the changes in flight pattern which is determined by wind direction.
See the same thing here.
NORTHERLY FLOW=more frequent interruptions due to VERY low flying aircraft APPROACHING the airport in front of the antenna.
SOUTHERLY FLOW= very few interruptions because aircraft is MUCH higher while DEPARTING the airport by the time the plane crosses in front of the antenna.
