Old 31-May-2015, 1:24 AM   #8
The adjustable attenuator showed up today and I decided to test it with the connection at main TV. Using the Hauppauge tuner signal meter I was able to dial in the proper amount of attenuation to reduce the pixelation on ABC, CBS, and NBC while still being able to receive Fox and CW.
Thanks for the report with the good news. Glad we were able to help you with an easy fix so that you didn't have to resort to extreme measures.
Being able to measure the improvement helps, as you can see by my signature.
What adjustable attenuator did you use?
