Tv Antennas and Reception
Also can run double the coax wiring , so will be one set of wiring for one antenna and a second set of wiring with the second antenna. And a Remote control A/B switch at each Tv location. This set up is really the best , no mixing of signals and the problems that come with it. If you were to make a post in the help with reception part of tvfool then we can help more.
