Old 29-May-2015, 8:10 PM   #15
PCoaster
I am aimed at about 165 degrees (pointing south) I am just using an iPhone compass and standing under the antenna to guesstimate the placement.
The channel that has the most issue is ABC (9-1). CBS (6-1) is also one that does it. To test if it is the amp can I just unplug it or do I need to take the wire from the antenna directly to the splitter (to bypass the connection with the powered amp)?
PCoaster is offline   Reply With Quote
