Old 29-May-2015, 6:38 PM   #4
Jake V
The "Magnetic" readings (last column in the TV Fool Report) correspond to what you will see on a compass. 304 is probably close enough, but you can try to better aim at 316.
You can also try different spots in the attic. If possible, stay as far away from anything metal (heating ducts, wiring, plumbing and exhaust pipe). You might just find a sweet spot. If that doesn't work, you may need to move it outside or get a better antenna.
