What direction is your antenna aimed at? Your strongest stations are all at 222 degrees on a compass (roughly southwest). CBS and ABC and some of your weaker stations are at 316 degrees (roughly northwest) and are 1 and 2 edge. If you have not already tried, try pointing your antenna northwest, towards the weaker stations. And try several locations in your attic, "looking" not through the roofing materials but "looking" through the siding if possible.
Attics on average lose roughly half the signal. Attics in houses with a metal wrap or in a stucco house can loose much more of the signal.
