Old 29-May-2015, 1:27 AM   #3
ECOMANCER
http://www.tvfool.com/?option=com_wr...f1f0b91c3dfad0
I've tried pointing antenna anywhere from 210-216 degrees or as close to it as I can by compass with antenna facing SSW on south side of house. The only object in the way might be part of a neighbors tree but it is a fairly clear LOS SSW.
I currently can pick up PBS 8, KHOU 11.1, KTRK 13, KTXH 20.1 is pixelated mostly, several channels in the 50's, several different virtual channels in the 13's, and some 60's. Currently the best run I got from the scanning of channels and moving antenna was 41 channels it picked up.
For some reason it won't pick up KPRX fox 26 or KPRC which is nbc local channel 2 which looks like it's labeled channel 35 on graph
ECOMANCER is offline   Reply With Quote
