Old 28-May-2015, 11:58 PM   #2
Jake V
1. Post the URL to your TVFool Report, and not just the graphic.
2. What direction is your antenna aimed? It should be aimed at 212 degrees on a compass (between southwest and south-southwest).
3. Do you have Line of Sight (LOS) towards the southwest? If not, what is in the way?
4. It might be useful if you post the stations you do get (real channel numbers, followed by virtual numbers) in the order they are listed on your chart. For example, KRIV 26 (26.1).
