Old 28-May-2015, 10:39 PM   #3
Jake V
Your TV Fool Report has a warning saying it is only resolved to the block level. You might generate a new one using the instructions found here: http://forum.tvfool.com/showthread.php?t=14508
You said you receive 10 channels? Interesting because your strongest stations include Fox and CW. Can you post a list of what you do receive.
Also, what direction is your antenna pointed? And what type of set top antenna is it? (There may be a part number on the bottom or describe it.)
If your set top antenna is a horizontal loop with rabbit ears you might try aiming the loop at the directions for the stations listed in your report. Use a compass and aim at the "magnetic" value (last column in the chart).
