Old 9-Feb-2010, 5:08 PM   #1
WazzuGrad
Reception Issues - Different Antenna Needed?
We're using a ClearStream 2 antenna w/pre-amp, feeding a 50" Sony HDTV (A2000 series)
Here's our report: http://www.tvfool.com/?option=com_wr...72433d3ff4ec64
We've reduced our cable run to the minimum, and it didn't help our signal strength at the TV.
Would a different antenna help? I've attached a listing of what we should get, along with the detail below about signal strength at our TV:
KWPX - Strength 92
KUNS - 92
KPST - 95
KWDK - 89
KCTS - no signal; Strength 41
KMYQ - 59
KUSE - 81
KSTW - no signal; 41
KOMO - no signal; 41
KIRO - no signal; 36
KING - no signal; 41
KCPQ - no signal; 41
KBTC - 67
KTBW - 62
The rest of the stations, we don't care about. Is there anything we can do to get the "no signal" stations better? Most of those are the major networks, which are the ones we'd want to get. Our antenna is approx. 30-33ft above ground level, using the stand provided with the package.
Thanks in advance!
WazzuGrad is offline   Reply With Quote
