Old 27-May-2015, 9:08 PM   #13
dovienya
What happens if you connect the antenna directly to the TV? If you said, I forgot. I'll go through the thread again.
I'm not certain that I had said much about that, and to be honest, it has been a while since I tried it.
I'm not entirely certain that I have tried that with the C2V in the equation. I know that I had tried it with at least one, if not both of the prior antennas. To the best of my recollection, the results were somewhat similar to the Tivo, with slightly higher strengths across the board. I think that makes good sense to me, since the Tivo has 4 tuners to worry about, while the TV only has one.
I should probably give the TV tuner another try with the C2V in it's current position, just to see if it provides any helpful information. The TV does it's channel scan fairly quickly, which makes it even less of a bother. Unlike the Tivo, which takes a minimum of 15 minutes to do a scan. I'll try to get to this tonight! (although I have been spending so much time fiddling with the TV that I haven't gotten around to springtime pressure washing yet. For the sake of domestic bliss, I may need to give the pressure washing priority tonight)
dovienya is offline   Reply With Quote
