What happens if you connect the antenna directly to the TV? If you said, I forgot. I'll go through the thread again.
In the attachment you can see the difference between the Antennas Direct and the older Radio Shack FM filter. The AD filter attenuates the FM signals at the low end near 88 MHz and TV CH 6, but doesn't remove all the FM signals at the high end near 108 MHz. The RS filter protects CH 6 for people that need to receive it, and does a better job of removing the FM signals at the high end of the FM band near 108 MHz.
