Old 27-May-2015, 5:15 PM   #8
shoe
In what direction is the Terk aimed? You have channels in many directions, and the best reception is when the antenna is aimed at the transmitter.
The Terk is pointed NW because the reason I got the antenna was to get WPMT and watch Eagles games. So, the antenna is serving its purpose.
I added a TV to my gym and didn't want to get another cable box so I got a Chromecast and connected the antenna to it expecting it would work fine since the other TVs in the house haven't had a problem with it. I'm surprised that the brand new Samsung TV can't handle the signal as well as other, older TVs.
You have many strong signals, the best ones from Baltimore at 246 degrees magnetic. The signal attenuation caused by the attic location is difficult to predict, but I think the amp in your Terk is being overloaded, or the tuner is being overloaded, or both. I would not have suggested an amp, just a good antenna in the attic, like the Winegard HD7694P or the Antennas Direct C2V.
Is the signal strength fluctuation shown by the TV a symptom of an overloaded amp or tuner? Reading the NM article you posted, could an attenuator potentially help?
shoe is offline   Reply With Quote
