Tv Antennas and Reception
I agree the Tv transmissions are plenty strong enough to receive. I am also thinking that there is some kind of connection problem. All of us that have doing been doing Tv antenna work for a long time automaticly look inside the coax connectors to see if the outer coax shielding is pushed in to ward the center wire and I have found out more the once that the connection part or equipment that can't be bad is the one that is bad. Many times that coax jumper that looks 100% good , is bad. Or the coax grounding block connections on the inside is bad.
