First, how did you aim your DB-8e at 147 degrees (southeast)? Did you use a compass? How sure are you that it is aimed correctly?
Second, you can certainly try an amplifier. Try one with an easy return policy in case it does not work. I'll let others provide a specific recommendation. Your Toronto signals are pretty strong, though less signal would be collected by the antenna since it is pointed towards Buffalo.
