OTA Signal Strength Fluctuates on New TV
Hello,
I just bought a new Samsung TV and connected my antenna to it. Immediately, I noticed the reception flickered every couple of seconds. When I view the signal strength on the TV, it fluctuates from a full signal to a half signal regularly causing the flickering. The same antenna connected another TV has no issues.
Should I assume it's the tuner on the TV? I've tried 3 different coax cables with the same result.
Any help is appreciated.
Thanks!
