Old 26-May-2015, 8:11 PM   #26
Originally Posted by Bud View Post
I aimed it at 31 and got nothing, also lost 28-1,2,&3. I then moved it up to 24 ft , aimed it the same(88deg) with no difference in reception.
Sorry to hear that.
WBOC has a NM of 68.8 dB and WRDE is NM 14.2 dB, for a difference of 54.6 dB. That is a big dynamic range. In order to think of a possible solution, I'm wondering if the problem is IMD spurious signals wiping out WRDE, or just WRDE being too weak, or maybe both.
Whatever the possible solution, WRDE or Baltimore, it will probably be necessary to somehow attenuate your strongest signals, or make WRDE a lot stronger to reduce the dynamic range.
How much trouble and expense do you want to put into trying getting NBC, with no guarantee that it will work?
What I have in mind is a 91XG or DB8E aimed a WRDE, a single channel custom bandpass filter for channel 31, and a preamp.
For WBAL it would need to be a high gain VHF or VHF/UHF combo antenna, a UVSJ or 2 in series to reject your strong UHF signals, and a preamp. You could combine it with your present UHF antenna with another UVSJ, no rotator or switches needed.
Did you ever call the WRDE station engineer to ask his advice?
Phone (302) 227-WRDE (9733)
