Old 25-May-2015, 7:51 PM   #1
at_hiker
Antenna advice for Clayton, NC
Here is my current signal analysis:
http://www.tvfool.com/?option=com_wr...f1f0dac16a657d
I'm currently using a RCA flat multi-directional antenna that sits on my TV stand, paired with a Winegard LNA-100 amplifier. This works okay for the local channels located around 3-5 degrees MagN, but from time to time I get a lot of pixilation that makes viewing almost impossible. I'm really interested in also picking up channel 25 (WUNC) which is located at 312 degrees MagN, but my current antenna can't pick it up at all.
Based on a recommendation that I got here a couple of years ago that I've just not acted on:
http://forum.tvfool.com/showthread.p...7179#post37179
I was getting ready to purchase a Channel Master CM2016 antenna and mount it on my roof.
Since it's been a couple of years I thought it would be wise to see if the recommendation is still optimal before making the purchase.
Is the CM2016 still a good choice?
Should I also purchase an antenna rotator?
What direction should I aim the antenna to get my local stations at 5 degrees MagN, and channel 25 at 312 degrees?
Thanks for any help you can provide!
Steve
at_hiker is offline   Reply With Quote
