Old 9-Jan-2011, 12:35 AM   #1
mcfl6
Combining multiple antennas
I want to combine two uhf/vhf antennas into one signal. I live in between two large cities and want to put one antenna on one side of my attic and another on the other side of the attic (pointing different directions), combine their signal into a single coax cable, and then run that cable to all the tv's in my house (through established splitters). I have done much research and am wondering if this is possible. Each antenna is an indoor uhf/vhf amplified antenna. I am curious if a diplexer or combiner is more appropriate. Also, i want to avoid "ghosting" since they may pick up the same stations. My guess is that the diplexer will work but I want to check on this.
mcfl6 is offline   Reply With Quote
