I just tried an experiment here with a couple of old RCA digital converter boxes I had from back in the analog to digital transition. I used a splitter to connect my antenna to both boxes. I set one box to output on channel 3 and the other on channel 4. I then used another splitter in reverse to combine the two outputs and ran it to an old 9" analog B&W TV. It worked fine. Of course this is not exactly what the OP wants to do, but it is similar. From that experiment I would surmise that sometimes it might work and sometimes it might not.
