Old 23-May-2015, 12:41 AM   #4
Tim
WRDE-LP on 31 is an NBC station. It is in a completely different direction from your other stations. You could probably use an antenna such as the Antennas Direct 91XG pointed at 88 degrees. Feed it with a separate coax line and use an A/B switch to swap between your antennas. Depending on the length of your coax, you might need a preamp.
