Old 22-May-2015, 9:55 PM   #3
dovienya
Rabbit,
Whoops! Yes, the 2v is actually the one I had been looking at. They have it at Best Buy, and I actually got impatient and decided to run buy one during my lunch break. It's a three day weekend coming up, so I'll have some time to spend screwing around with an antenna. Unless I luck out with it inside, I have I suspicion I will be clamping it to a broom handle and waving it around like an idiot from the 2nd floor balcony for part of the weekend.
Ultimately, I want/need to get the "usual" channels to get this far enough along to justify cutting cable TV. I am very much hoping to be able to get ABC, CBS, NBC, OPB, KPTV, Fox, and CW or WB or whatever they call it these days.
I had not even known to check for the low-e glass! Thank you for the heads up on this. I know the glass in the bay windows looks like it is "nice", so I will look for any type of indicators when I am home later today. Despite the windows having a view up the west hills, maybe that has actually been a bad place to be testing things out.
Here's hoping for good results with the clearstream! If this doesn't turn out to do the trick, I may be running out of reasonable options. I'll follow up over the weekend after I have had a chance to test things out.
dovienya is offline   Reply With Quote
