Old 22-May-2015, 3:31 PM   #3
Kasm
Thank you ADTech.
If I move the antenna up to my roof, does my ground line have to run to my electrical service ground which is on the opposite side of the house? Or can I run a separate ground and/or tie into my lightning system ground?
Also, you say the Boston channels are weak, byutthe TVfool report shows the NM between 15-25. I read about 0 should be receivable. Is this not correct?
Kasm is offline   Reply With Quote
